Hello everyone! I have a Fiat Siena 1.3 Year 98.
I will present two problems that may have a relationship with each other.
The first is that a fault is recently presented, which made the engine lose strength and turn off, if it turned on again, it barely kept on. However, after half an hour, trying to enclose it, I made it without problems and underway it worked well. The injectors had a service a month ago and the gas filter was changed a month ago. The pressure pump pressure was reviewed and is normal. A Scaner was applied to the computer and all the sensors marked well. Maybe everything indicates well since the failure has been export.
The second problem happens just after the revision, in the morning and with a slight heating the car is colored. Minutes then the engine makes a mild explosion noise and throws a little blue smoke due to the escape, followed by the loss of strength and barely keeps lighting. Testing with the spark plug cables, it can be detected that there are two pistons that are not working, and I presume that it can be problems with the valves or stamps that keep the fur from the Ignition camera away. I would like to know the oppression of some mechanic about these symptoms, if I am right in my presumption of the recent failure and if so, what are the possible causes of the problem when the valves fail.
Note: The recent failure is the second time it happens to me in six months.
I appreciate the advice you can give me !!
