Ford Explorer Loming Failure
15 years 10 months before #8864 by manual-mecanica
Manual-Mecanica Response on the Re: Ford Explorer Failure
Is it sure you have no ignition module ???????
15 years 10 months before #8869 by manual-mecanica
Friend if you have one, I do not know if it is called a module, but it works because it actually elevates the tension and it is doing it at least that I believe because the other cables the spark arrives well, there are only two that do not have high tension. I would need the circuit to see the issue of cables. A hug and thanks
15 years 10 months before #8876 by manual-mecanica
I don't know why the manual that I publish give me your email have not uploaded and I pass it to you
15 years 10 months before #8883 by manual-mecanica
THANK YOU
15 years 10 months before #8890 by manual-mecanica
B) This will serve you cause it and let me know
