Estimated, finally take my car to the mechanic that thoroughly check what the cause of noise, check, homokinetic, box bearings, dough bearings, trice, etc. And these did not present any problem, that is, the noise was not one of those sectors.
What he did was apply W-40 in all the parts that could be dirty or grouped where there are bushings, supports, etc.
Once this was done the noise I felt next to the right wheel, I disappeared, I suppose that some piece was dirty and was what caused the noise on the right side.
Anyway, my mechanic found that the axis of Palier had enough game on both sides of the cash output…. But despite this there was no anomalous noise.
The other noise in the direction when I turn only to the left side, check the levels of hydraulic liquid and were on the maximum, I took a little left at the normal level, but the noise continues to be heard, apparently it comes from the zipper of the direction the direction the noise is like a buzz: Buuuuuuu! And only hear when he turned left or if one turns the direction to the right it sounds when the straightening ...
I wait for her comments.
Greetings.
