Diagnosis of homocinetic
16 years 3 months before #7290 by manual-mecanica
Homocinetic diagnosis published by Manual-Mecanica
How my consultation is: how can I determine if a homocinetic is with wear, to simplevista the balls and the channels are without rallas or chopped, in advance thanks.
16 years 3 months before #7293 by manual-mecanica
Manual-Mecanica response on the RE: Diagnosis of homocinetic
Hello, many years ago I left the mechanic of the car professionally, but I still remember the "evidence" that we did to the vehicles.
If the overall is not broken and the homocinetic joint retains all the fat is usually a good health symptom. Generally when a homocinetic joint this deteriorated usually makes a characteristic noise when turning the direction with the car in progress.
Greetings.
16 years 3 months before #7332 by manual-mecanica
Homocinetic joints when spoiled emit a shriek when folding to any of the sides, if they do or do a blow, it gives percentage that are in good condition, the wear of the components if it is not noticeable then it is despised, there is nothing more than that.
16 years 3 months before #7369 by manual-mecanica
I appreciate the fact that they have had the deference of answering my unchanges, however what happened was as follows:
there was a slight noise in the left front wheel, the vehicle is built and the noise is turned and the noise is frightening, as if a bearing were made trizas, when taking the wheel an exesive game is denoted as if the wheel bolts were loose. The complete and homocinetic set is disassembled has a slight game as if the channel of the balls are worn, the semi -axis that enters the differential
planetarium
16 years 3 months before #7372 by manual-mecanica
Thank you for the solution, the moyoria does not and in this case it is good so we can help other people with the same problem,
