Hi Kikemec, look for me the problem that the car has is the ignition module the Q fails, what happens that the module goes inside the coil so you will have to change the coil, I already spent a corsa of those
I spend something `similar was the turning sensor, which is between the engine and the change from the bottom on the side towards the habitaculus of the car
Hello, I request help in a 1.4 EFI corsa, it stops without any logic and normally turns on at three hours, during that period it does not sparkle to the spark plugs, the coil changed but the problem continues, consult the mechanic and told me that this model has no crankshaft sensor ... the ignition module can have this behavior or when it breaks it is broken without further?
