CHEVROLET OPTRA RETAINER PROBLEM
11 years 4 months before #45471 by manual-mecanica
Chevrolet Optra Retainer Problem Published by Manual-Mecanica
Friends good day ...
I have a problem with a minimum oil leak from the box, by the retentive of the left axis that is stuck to the box I already changed it 2 times and the drip is still there, I don't really know what is the problem that there is the leak. If the 2 retainers on both the left and the right have been installed correctly ... I do not know if it may be that the same axis to the rolling momet produces the damage because it has some type of twist or aboller. Please help me confirm this problem ... thanks
11 years 4 months before #45477 by manual-mecanica
Manual-Mecanica Response on the Chevrolet Optra Retainer Problem
You should put the retain more inside if you can or something else out, if the axis has wear where it slips the retain (many kmts ..) always coincides in that channel and does not squeeze well there ... the fact is that it is not touching where it always does. Greetings!!
