Help Chevy 2002
11 years 4 months before - 11 years 4 months before #45437 by manual-mecanica
HELP CHEVY 2002 Published by Manual-Mecanica
Greetings
I just changed the water pump and the thermostat to Chevy but when the car turned on and use the temperature needle it does not rise or move at all. The Normal Enter
is a Chevy Swing Mod. 2002
Thanks for the aid
Last edition: 11 years 4 months before by .
11 years 4 months before #45439 by manual-mecanica
Manual-Mecanica Answer on the topic Chevy 2002
Good friend did not connect the thermostat of the clock that is a single cable with a connector lined with a plastic that goes near the valve cover where the injectors go near or under the manger of the gases of the same
11 years 4 months before #45440 by manual-mecanica
It is a small copper color where you should connect the cable from which you speak
11 years 4 months before #45582 by manual-mecanica
Sorry for not answering fast but I had to get out of emergency
thanks for the help since Chevy is
