About 6 months ago I acquired a nuance, from the Pontiac, it is 2006, well, the problem is that it accelerates and low An English manual here, but the acceleration body does not look the same. To end it to gather it, today when returning from work, when the criastales climb, the co-pilot did not go up (they are electric), the other goes up and low normal, well, I thought of being a fuse- and has reviewed the boxes, which to top it does not understand what they bring marked, well, I reviewed one by one. correctly, I read here and there and as something similar to spark is, because I saw a diagram of the spark fuses and mentions that it only brings a fuse (I think 30a) for both crystals, so if one goes up and down normal, may the engine of the other glass be damaged? Or the nuance brings some individual protection for each engine of the elevators? That is my doubts, what also noticed when I returned to the house, that there was a smell like a melted rubber, something like that, because I open the chest and the smell comes from the spark plug cables that I changed (marked and in the same order) can it be normal because they are new? I only toured about 5 minutes from the chamba to the house ... Well, here were my problems, I had not given me a can, so far.
I hope to have your valuable help, I do not know if there is a manual for this car on the page, I thank you in advance for your valuable support.
Atte: Martín Santos
Q, Roo, Mexico
