Yes, I have taken all the right steps as the manual says. The only thing is that it has only happened to me with this type of vehicle, 3 times and the latter put the diagnostic equipment and only showed me in the UCH, connection impact information. I changed the impact sensor for a new one and nothing, the installation measured it, continuity to already positive dough and there was no short. Finally I tried passing the ECU, UCH and the contact key to a good car and in that one did not give a breakdown in the UCH and therefore ignited the engine. Then I made the steps that the manual shows when you have this fault code and the failure can be on the multiplexed network I do not know, I simply had no electrical schemes to test.
