White smoke
11 years 7 months before #43840 by manual-mecanica
White smoke posted by Manual-Mecanica
Good evening, I need your help, it turns out that I have a Toyota Prado Truck year 2004, it has just repaired the engine, its compression is in optimal conditions it has in 440 psi, this is a 1kz-you engine, well the problem is that when it warms out it begins to come out white smoke by the escape, and it smells like pure diesel without burning, they chop the eyes when you know, I want to I will be very grateful. Note. This engine is Turbo Intercoler.
11 years 7 months before #44086 by manual-mecanica
Manual-Mecanica response on the white smoke
Hello, it seems to me that the injection pump is poorly trained in the best, or badly traced the distribution chain, review the Distribution Distribution points and check the injector's draft, that another does not occur to me now .. luck
11 years 6 months before #44198 by manual-mecanica
Hi Jamosa.
In addition to what Ismael tells you, check if the water level is lowered, it may be that the turbo cooler is with escape, it can also have a water pass through some cylinder, the itching in the eyes is because of the bad combustion that the failure produces. LUCK
MIGUEL
11 years 6 months before #44199 by manual-mecanica
Look at me that it is an injector draining that it is not pulverizing
