starting problems in a Hyundai Terracan Diesel
13 years 7 months before #27533 by manual-mecanica
starting problems with a Terracan Diesel, what tries they recommend to realize to detect the fault
13 years 7 months before #27592 by manual-mecanica
There are several tests that you have to perform, depending on whether the engine is electronic or mechanical, it is usually lack of diesel, broken hoses, covered lines. This is the elementary. And the first thing you have to review before doing something else
13 years 7 months before #27601 by manual-mecanica
Hello, what kind of Terracan Crdi or TDI 4 or 6 cyl
13 years 7 months before #27602 by manual-mecanica
Hello, as the partner says there are several things to provise, you can also check the incondent spark plugs, and that the food system does not have air, if it is with an injection pump to see if 12V arrives. To the oil cut valve and if it is Camon Rail see the pressure of the oil
13 years 7 months before #27603 by manual-mecanica
Hello, and greasias to you for answering me. It is a CRDI engine 2.9 year 2006
