Oil leakage
13 years 8 months before #26995 by manual-mecanica
Manual-Mecanica response on the Re: oil leakage
Sometimes the carter packaging is broken right in that area and oil loss is confused by the rear retain
13 years 8 months before #27026 by manual-mecanica
I think the two companions are right. If that were not sometimes the rubber accommodations are fined, and simple eye it is not seen. Salu2
13 years 8 months before #27057 by manual-mecanica
Thank you all for the opinions on the subject will take into account each of these details when reviewing
13 years 8 months before #27172 by manual-mecanica
I do not know if it helps you but I have seen that happens when the retainer or seal used is not the right one can be well but inside the seal it brings some lines that are called stark and on the surface where it has the numbers it brings an arrow this indicates the direction of rotation of the piece in which the seal is mounted if the arrow indicates the turn unlike the turn of the crankshaft. A friend with the seal of a Honda was given the seal of another engine and the turn was different. The other may be that someone aya damaged the crankshaft track and you have not noticed when riding it, check it careful mind and make sure that when mounting the new seal is adjusted to the center.
