Opel Corsa starts, I stop it and no longer starts
13 years 8 months before #26952 by manual-mecanica
Opel Corsa Viva Diesel of 98, new battery, starts, a few meters ago, stop it and no longer starts, as if battery fails, if I do not move it starts 2 or 3 times without failing. It can be the alternator. It does not mark witness witness, but if the surcharge starts.
13 years 8 months before #26954 by manual-mecanica
Hello friend, try a multimeter if, when accelerating there is an increase in battery vote if the alternator is so loading
13 years 8 months before #26969 by manual-mecanica
Estimated, to rule out if it is the alternator, when the engine is running drums, if the alternator is fine, the engine must continue to work, if the alternator is with problems, the engine stops immediately.
This comment helps you
greetings.
13 years 8 months before #26996 by manual-mecanica
I play once the same problem in a Corsa and the problem is that the cable was isolated, the negative terminal that goes to the chassis (body) not to the engine's block, hopefully it is the same problem
