Water from the lava -paving does not work
13 years 10 months before #24806 by manual-mecanica
I have an Hyundai Matrix Diesel of 2004, and the problem is that the wasopher.
Lugo idea what can happen to you ???
13 years 10 months before #24814 by manual-mecanica
Manual-Mecanica response on the Re: Water of the Wardrobrisas does not work
Although it sounds weird the first thing is to check if we have water on the deposit, then prove that the engines sound when activating them, if they do not sound check that the engines are good trying them in direct battery, if they work the problem it is in the command, if they are not the engines, if they sound with the command the handles are covered,
13 years 10 months before #24816 by manual-mecanica
Thanks for your answer.
As for the liquid, if I have, and the engine, when I give Almando it does not sound, so my first idea was to check fuses and relays, either I know if in those I checked was the clean engine, since I do not have much idea of ​​mechanics, so I look at the engine part and those inside the cabin, but I do not know if I will have left any to look.
13 years 9 months before #25594 by manual-mecanica
Hello, I had a similar problem. I noticed that the water pump engine was heated, but I did not vibrate, I decided to remove it, and check if I had to buy it, disarmed it, and I found the engine I was oxidized, but intact, I tried it again and it didn't work, with some tweezers I turned the rotor, and it was very tight. I tried it again and worked. In my case, he had hit the oxide.
13 years 9 months before #25595 by manual-mecanica
Thanks for your answer show ... Let's see if I have some time to try what you tell me.
