Estimated all, good afternoon
I tell you that I was checking the car for a while and taking some photos to send them. First, I clarify that I never had an idea of the function of the car and now I am trying to learn a little not to fix it but to have a little idea of the problem and know something when I speak to me the mechanic. I will make a summary of the current state of the car to avoid confusion. They already apologize if I ask very winds and thank you all for collaboration
1) the car when I start it takes to start, but luckily it starts, but when it sometimes walks "pull" or "it is award" (as if it were going to run out of gasoline but it has the tank almost full). Will it be the carbons that are spent? Once it happened to me that it took to start and changed the carbons and was solved, how can you know whether or not the carbons are?
2) It does not have the thermostat. Can the radiator purge be done just as Santi indicates in the link Federico happened to me?
3) I noticed that the radiator lid is deteriorated, a black gum (like washer) that is around the lid.
4) The lid and the radiator (where the liquid is placed) have dirt (it will be solved if I put the new lid and make the purge as Santi says?)
5) I was not putting refrigerant liquid or distilled water this last time. Only common water. Now they explained to me that it is very important and I will do it again.
6) Sometimes (not always) when the heating turned on, a cooling liquid fell to the companion's carpet. Why can it be?
7) I did a test today. I placed water to the level, I covered it and arranged it, then stopped it and waited for a while, I opened the lid and the radiator was full, 20 minutes later I came to work and when I arrived (5 blocks), I waited a little while, I opened the lid and the radiator was dry. The floor was also dry. I noticed the car and the Chapion was wet from the bottom. Can I have lost water on the road and that is why it does not show on the floor? Where can the water go? Will a radiator hose be broken? If so, because the water does not fall to the floor? How much is the normal water/ refrigerant that must "consume" the car? I checked the oil and thank God it has no water. Below the photos, of the doubts and of my machine to know it, of course. (Excuse me but I can't upload the images I send the link)
postimage.org/image/2gingn6n8/
postimage.org/image/2ygzfkyqs/
postimage.org/image/2gjam61k4/
postimage.org/image/2yj3iaxgk/
