Hello, I attach a basic image of how the loading system is, marked in a circle are the diodes that prevent the current from flowing from the battery to the alternator windings.
It may be that the burned one occurs due to a malfunction of these diodes, the best thing that can happen to you is that one fails and is in open circuit, while the failure is in short circuit it can be given that the current changes meaning and balla of the bat. to the babinee of your alternator.
I propose to carry out a test the three cables that enter the regulator, without the alternator connected and preferably with the BAT disconnected. With the polyymore (tester for me) in diode or continuity test between the three cables, it must give open circuit in all possible tests of test since there is always an inverse diode, the same between the three cables and mass or 12V, it must always give open.
Be careful that this test is for the diagram of the figure that attached, if you have the internal diagram of your regulator, I ask you to share it and analyze it.
Greetings.
imageshack.us/photo/my-images/263/basico1g.png/
PS: I hope you see, I have a FZ6.
