Chevrolet S10 Chevrolet Light 1998
13 years 11 months before #23423 by manual-mecanica
Manual-Mecanica Response on the Re: Chevrolet Light S10 1998
Since before, it was spent since the light of the check was caught, the mechanic still told me that by changing the oxygen sensor, the speaker would happen, but nothing happened.
13 years 11 months before #23426 by manual-mecanica
If with the new sensor I should spend less, but also does it if you change the temperature sensor, but it has nothing to do with the light that ignited you.
13 years 11 months before #23428 by manual-mecanica
Good morning
friend
did not answer me if some numbers like codes in the scanner appear, or since your truck was, it would be good you will tell us. Greetings Wilbert
13 years 11 months before #23432 by manual-mecanica
Sorry was out ...
Well, the mechanic did not give me an alphanumeric code, only the "TCM".
I still have the problem.
The really good thing, it would be that someone has the Chevrolet S10 1998 software, to identify 100% the fault code.
13 years 11 months before #23466 by manual-mecanica
If there is check light ..Hay code .... what is it?
