Aldo is right first to clean to be sure where the escape comes from and second is also more less in the right thing, in general, Peugeot uses the bench one that is the first one from the box has the distribution, as a joint and if he wears some rubber cells on the side, but he also has a retain where the steering wheel of anyway will have to lower the box and if the fault are the side of the gum of the bench. Download only that luck bench, first Czech where it is.
