Ford Explorer Sport 2001 sensor failure
14 years 2 weeks before #22446 by manual-mecanica
Manual-Mecanica Response on the Re: Ford Explorer Sport 2001 Sensor Failure
Good afternoon. Today I took out the sensor 1 of Bank 1 and was very full of carbon, had the gray cable and a white peeled and glued together. The other two oxygen sensors were in better condition and all of them had been cleaned in the same way two months ago. Replace sensor 1 of Bank 1, the car feels without strength at the time of starting and then takes strength. For tomorrow I am going to clean ultrasound injectors to see how it behaves.
14 years 2 days before #22842 by manual-mecanica
Comrade If you have a very strong smell in the Salaida de los Escapes, the problem is that the Catalix
Zadores are very covered. of fuel. Like all these sensors, they work in the entresi the scanner send you several codes but it does not tell you anything specific to do not checked physically all these components. [
14 years 44 minutes before #22881 by manual-mecanica
The oxygen sensor, left before the catalyst does not work, or the cables are damaged, Quitalo check it and wash it; spark plugs 1 and 3 are not working (the first and last on the left side) this can be due to damaged cables, damaged spark plugs or your coil no longer works.
If the cables are new, check that they have +/- 5K OHMS.
Check spark plug calibration.
If everything is ok, your coil already gave them.
The flat sensor does not work, it is driving your computer crazy because it presents rich and poor mixtures.
A symptom is that the troca has no strength, and it must be spending a lot of gasoline.
