If it is the IAC valve, you can try it accelerating and releasing, if it falls to less than 1000rpm and then it is paired it is the dirty valve.
The step by step I do not think it is since if it were this, the scanner detects it to you, it also had to pass you throughout the day. You can disconnect the same that nothing happens.
Good luck and greetings ..
