Problems with a Ford Fiesta
14 years 1 month before #21353 by manual-mecanica
Manual-Mecanica Answer on the Re: Problems with a Ford Fiesta
Paty: I imagine that you have already seen that the water is crying and thus discard the water pump ... how long is it heated ??? They are countless possible faults, but there are going little by little discarding ...
14 years 1 month before #21359 by manual-mecanica
First, what are nothing to check if the electrventilator turns on when appropriate, that is, if it is activated at 90 but after this, if it does to the nineties and yet the vehicle is heated then you can suspect a problem with the ampake of the cylinder head, to check if it is the cutlery butt to realize some simple test The radiator or expansion deposit water is not contaminated with oil, then removes the lid from the radiator or expansion deposit if it is your radiator does not have a lid, and give the car to the car if it jumps water then the compression is escaping to the refrigeration system. Electro command is done by the computer, if this is the case you can perform a parallel installation that is cheaper than repairing the KE. Test and let us see how we continue.
14 years 1 month before #21362 by manual-mecanica
Good evening friend 1st you have to remove the water pump, there are three 8mm screws verify that your blade does not have a plastic ring after the blade if this good verifies that the hose that goes like this in the water empt Take it to a rectifier to brush it because it can be folded and if it folds the compression, it takes the water from the engine to evaporate as the engine I hope my help serves you but first you have all this happened and then it tells me how it was like it was
14 years 1 month before #21368 by manual-mecanica
Well, I don't know much I like to learn but I think the water I think I will see k see but tell me how I take it x Step and the car heated according to yesterday with him and he has not heated anything I was around the city and nothing up the needle but I went down and the radiator felt it to light as I can give myself how much k is the bomb
14 years 1 month before #21369 by manual-mecanica
Ok I am going to look at the hose is fine the k goes to the water tank and towards the radiator I am not very new in this I am also a girl I really like the Kiero Mechanica Learn I hope your answer Kisses
