Problems with a Ford Fiesta
14 years 1 month before #21438 by manual-mecanica
Manual-Mecanica Answer on the Re: Problems with a Ford Fiesta
Ola how much k is almost 5 years old but they told me to the Board of the butt and once fixed it xk tube a car and I fuck me but it looks Kedo bad x that it hots but it is Ford festival guide of 2006 90 cv I do not know more to tell you but the radiator is well ventilated the thermostat and nothing remains almost the same does not heat so much but the water is boiled and the water At the way in the air they told me that the engine was that air did not know anymore a kiss
14 years 1 month before #21440 by manual-mecanica
The detail is that on the outside the radiator looks good but inside the tubes are covered only to lower it and probe it is cheap that if it is not disposable :)
14 years 1 month before #21469 by manual-mecanica
Ola but the mechanic told me to be the joint of the butt more k The xkx pump the water hose comes out air instead of water yx that heats up the water but 1st had to check the pump and if it was the other
14 years 1 month before #21474 by manual-mecanica
To check if the pump is disconnected the upper hose of the radiator, the car is turned on (of course it is pushed to the radiator) it accelerates a little and if water votes the pump is very clear that it must throw it with a pressure between more accelerate more pressure there are :)
