I had a problem similar to that you mention in an ocación Checate the following, the problem that my car had was a constant viberation with the engine on, not being underway, when making a strict review, the following were detected after the engine stands were defeated, that is to say the right motor support, the left and the one of the box, the change of these was made and the vibrations decreased but the vibrations were still Surprise The exhaust pipe was damaged had certain holes as well as the exhaust board were replaced and the vibrations disappeared, as Data Checate also, the ignition coil when it does not work at 100 porcirnto emits vibrations since there is a motor cylinder that is not working due to lack of spark.
