Ford Transit
14 years 1 month before #21305 by manual-mecanica
Manual-Mecanica Response on the Re: Ford Transit
Hello pruning, I did not answer before because I just just arrived the good van the changes enter well ... the time I try, the owner says that times are hard but well the biggest problem is a strong sound that when stepping on the pedal of the clutch disappears, take out the plug of the olio and did not fall or 1/4 of olio, did not kisar to lower the box again if everything is new only work 1 First thanks to all ciaoooo.
14 years 1 month before #21307 by manual-mecanica
Well Puma_01, did you not change the oil to change? How did it lowered only 1/4l. Did he miss it somewhere? I hope the change has died, because it would be a whore. Add a little dense oil and make a little route and throw it, so that all the remains of chip fall. Then you put a SAE90 oil (Motul Pa90) this luxury, for the boxes they have suffered. Well, I don't give you more toast, there is luck and salu2.: EVIL:
14 years 1 month before #21331 by manual-mecanica
Good, what happened to the oil is that the owner said that he changed it later in tap, also when he uncovered the plug to fill the oil a little but at the same time I saw it complicated to fill his finger by put his finger and felt that I ran into something I think it was the tip of the cardan I do not know if he opens a simpler pod to put the oil
14 years 1 month before #21351 by manual-mecanica
Friend if the noise disappears when you step on the clutch then that noise is of the gearbox clearly, but this noise does not disappear after a while, if it is due to lack of oil it persists all the time, I believe that it is best to assemble the passance and fly the box again, and check the pilot axis has no game or longitudinal, so you tell me to sound to me to problems.
14 years 1 month before #21422 by manual-mecanica
Hello everyone, well, I arise with the passance and to diagnose the problem better, the sound was not the filming of the clutch, it was inside the box due to lack of oil but I could not fill the oil through the filling plug tube that making it dismantling a bulb that goes above the hydraulic actuator once done all this turns on the van and disappeared the sound, the problem was only the lack of oil, there is only one and the age of the box but I improve in everything: Silly: good; Thanks for your interest and collaboration until the next ciaoooooooooooo .....
