Problem with Chevrolet Corsa Wind 94 Monopunto
14 years 4 months before #18748 by manual-mecanica
Thanks friend Miyagui, well if with respect to the oil, because it was that, the oil when changing it came out black color practically did not serve, and well we changed the oil and oil filter and the problem of the flicker Too much gasoline and that makes it not expand well and you lose power according to the mechanic., Well I hope in these days change everything that is missing and I will tell you how the corsa progresses, first of all thank you very much for all its aids ..
Delis
14 years 3 weeks before #22239 by manual-mecanica
Greetings I love Delis29. My question is if you already solved your problem with your Corsa I have the same problem that the gasoline pump changes. and from the next day I changed. that when a prayer for a semaphor as it was worse in a rise up and a lot of black smoke. I have already taken several mechanics and none gives me a solution. That's why my question that if your corsita solved it thanks ..
14 years 1 week before #22597 by manual-mecanica
What if, problem solved. What happens the air filter did not serve and towards that not enough air to the admission camera, then the gas pressure regulator is moved and the point is not synchronized. solving all that. The car was ok only that right now is consuming me a little gas, for a sensor that is defective (the MAP), verifies that the filter is bine and the TBM synchronism, must improve with all that. Let me know anything.
14 years 1 week before #22598 by manual-mecanica
Thank you for answering friend calex, you could tell me where the fuel precion regulator is .. I have a 98 Corsa Wind .. and how you did to repair it or I have to take a mechanic thanks ...
14 years 1 week before #22600 by manual-mecanica
Hello! The pressure regulator is in the same body of the monopunto you should take the fuel pressure some regular mode in others, not the pressure should be in the order of 1.0 to 1.2 bars if it is higher you will have an excess of consumption and it will work completely drowned
