Hello again, although it is so what you say Fiat147, the issue of friction and the pumping effect, take it into account, but I think that rather, the issue of shortening a career to an engine is given according to its use, to explain it better: being the shortest race, the time you need to make a complete turn is less than one with a long race (since the distance is greater in this case, from pmi to the one that determines the speed of the embolo .. and say that, at more speed, greater inertia of the mass of the piston-white set. Suitable for high RPM number, it is the short running engine, both for the shortest turn time (rises faster) and by reduction of inertia and the weight of the connecting rod to be shorter, (it is lower)
on the counterpart of this engine, the torque is located at a greater number of rpm, but its power is greater when reaching a greater number of revolutions (greater mixture mixture x minute). I suppose that you know all this, as is why of the engines of 6.8 or 12 cylinders, to the highest number of cylinders, lower speed of
embol Fiat147 Get the dimensions of any of these engines and calculate the speed of Embolo ... some may not exceed 15 m/sec. A 16,000 or more rpm ... that is, even less than the 1ZZ, which is from street ... in case of overcoming it that the weight of the materials of these F1 has some inertia of mass, very small compared to what we know (namely what the rods and the pistons are made ..
) well, this topic would give for months ... greetings, and remember that they are only opinions
