Trailblazer problem P0300 code
15 years 11 months before #10368 by manual-mecanica
Trailblazer problem P0300 code published by Manual-Mecanica
If someone can help me with this problem, I appreciate them,
I have a trailblazer with a P0300 code and I have revived the compression and okay, the spark plugs are new and original, the coils are also in good condition, the EGR works correctly, take out the escape in case it was clogged or overheat, the injectors are also tested and they are well.
15 years 11 months before #10373 by manual-mecanica
Manual-Mecanica Answer on the Re: Problem with Trailblazer Code P0300
What tells you the code
15 years 11 months before #10377 by manual-mecanica
Hello, the P0300 code means that there is an exploration failure in one or more cylinders if you already revived everything you say, it is sure that you occupy an injector washing and what has to be done in these cases is to check with an online data scanner to really know which or what cylinders are the ones that fail
15 years 11 months before #10387 by manual-mecanica
ignition failure in indeterminate cylinders
15 years 11 months before #10388 by manual-mecanica
We use a Bosch scanner and different cylinders fail and not always the same
