Common Rail Common Injector Voltage?
15 years 11 months before #8770 by manual-mecanica
Common Rail Common Injector Voltage? Posted by manual-mecanica
Hello, Alguen knows exactly what voltage should reach the injectors of Common Rail in a Citroen C3 HDI. 8v. (Siemens)?
15 years 11 months before - 15 years 11 months before #8773 by manual-mecanica
Manual-Mecanica response on the Re: Food voltage Common Rail injectors?
Hello, the common injectors its voltage is about 90 volt to take this voltage you need to measure it with an oscilloscope because its frequency is very fast with a tester will you not be able to see anything, a question do you have any problem with it?
greetings: Laugh:
Latest edition: 15 years 11 months before by .
15 years 11 months before #8849 by manual-mecanica
Gentlemen we use the logic when we write something and read what we write before sending it, explain a bit which is your problem in the car or if it is only an informative character.-
13 years 9 months before #25741 by manual-mecanica
Hello the feet, they work in full load in 120v dc later work between 100y110v according to the regime
