I need a little help
15 years 11 months before #8615 by manual-mecanica
I need some help published by manual-mecanica
Good afternoon. I am new in this forum and I am looking for help if it could be to fix some small nonsense of my Mercedes 190e.
I know very little mechanics although a friend who understands something more than me is going to give me a hand .. why don't I take it to a workshop? Because I have no money to invest in something that I am convinced can be fixed without spending anything
I would do a very big favor if someone told me because it is already a question of pride.
Greetings and thanks !!
15 years 11 months before #8631 by manual-mecanica
Manual-Mecanica Answer on the Re: I need a little help
What bacius bomb are you talking to us? What type of closure do you have and what is the problem that has the closure is sentralized?
15 years 11 months before #8656 by manual-mecanica
Hello partner, it is true many Mercedesz brought the blockade with a pump taking advantage of the void that probes the engine, some you disarms one but from 89, they bring an empty reservoir, on the left left side of the trunk, to get to it you have to only remove the upholstery, but the easiest way to reach the problem is following a hose from the doors and it is burning until reaching the origin of the empty or reservoir. Main hose from the engine is broken or disconnected. luck
15 years 11 months before #8666 by manual-mecanica
Thank you very much !!!, I will look at her that happens ... although the problem I have is that I leave myself thrown yesterday ... I think it is for the battery but the windows work, lights etc. (also the battery is from 2004 and I had to tear it out with the tweezers but the car worked perfectly all afternoon).
Suddenly the flashing stopped being operated while the car on ... I stopped to look at them and perfectly started the car to solve it in my house and the 200m had trained and waiting for the front to come out the engine (I had the clutch stubborn x so much did not fit).
It makes the attempt to start ... one thing that seems very strange to me to try several times the engine does not smell like gasoline ... I almost get the car hahahaha
if you can take a hand ...
