The same problem of Focus 2000 in Mondeo 2002
16 years 1 month before #7915 by manual-mecanica
The same problem of Focus 2000 in Mondeo 2002 published by Manual-Mecanica
Hello, how do I have the same problem as my partner of Focus 2000 the difference is that I already try from everything to change the original pump pump gasoline filter and check that the hoses do not have any escape I hope they could help me solve the problem thank you
16 years 1 month before #7938 by manual-mecanica
Manual-Mecanica Response on the Re: The same problem of Focus 2000 in Mondeo 2002
It would be useful that you remind us what your partner's problem was because we don't all remind us of the problems, it is worth it, greetings
16 years 1 month before #7941 by manual-mecanica
Ok looks at the problem was that after a while to use the car, he began to fail and check with the manometer the precion went down and began to fail immediately that he went out again turned on it again and he could move forward one more akilometer and lower the precion precion already check gasoline pump etc.
16 years 1 month before #7949 by manual-mecanica
Ok looks at the bombs are calibrated for a pressure, it is said to actually a flow is generated by the system. This is in ingiery hydraulics, well, to the corsa the fuel hoses are pierced and eentra air to the injection system this produces failures and lows of precion can be a problem or pump That is what is missing when your engine stops whether it is fuel or spark, is the first to know where to look since check does not indicate anything vverdad?
16 years 1 month before #7962 by manual-mecanica
Passasol, our partner has already resolved the problem reviewed his post there, everything I do so is well explained that is how lucky and leave it is the same solution for you, just a little cleaning and now.
