ECU in emergency
16 years 1 month before #7829 by manual-mecanica
Manual-Mecanica Response on the Re: ECU in emergency
By the way, to erase all the codes that are stored, disconnect the battery for at least 5 minutes or use the scanner and there if to see if the problem was fixed with the cleaning of the ducts
16 years 1 month before #7846 by manual-mecanica
It is correct what Alge says you must be careful the ECUs can be bridged but only to obtain fault codes nothing more, if your vehicle has airbag and you can activate it so it is not recommended, now whenever a repair is done, you must prescribe the ECU, the fault is stored until you enlarge it and it does not leave the state of emergency prescription and it is already.
16 years 1 month before #7850 by manual-mecanica
One question: what was the OBD diagnostic code that showed the scanner when they connected it?
