I ask for your opinion for the diagnosis of my car a Nissan Platina (Clio, Thalia, etc.)
Well the problem I have is the following:
I have a problem on the front tire The symptoms are
- Sordan noise (a little serious) when walking as if something brushes (already verify the tire does not pink with anything), it is not metallic noise.
- When turning to the right side to the top the tire tends to zigzagear, that is, as if it is not completely found in vertical position.
- The address tends to go slightly.
- And when accelerating and slowing down, a slight click is heard, as if something will stay after (from this I still do not verify the lower support of the engine that is balancing)
I still do not deduce what it is and for lack of time I have not been able to disassemble to verify.
what will it be?
The
Homosinetic
I hope you can help me in advance thank you very much.
