HORN
16 years 2 months before #7512 by manual-mecanica
Horn published by Manual-Mecanica
Hello, I would like to see if someone can help me! I have a caravan 98 and the horn does not work they tell me that it is the clock spring and I would like to tell me if it can be repaired and how to do it or have to buy it thanks
16 years 2 months before #7514 by manual-mecanica
Manual-Mecanica Response on the Re: horn
In general, the repair exists, but for Craisler it is expensive, what you fight to do if the horn work directly with the battery, that is, it is in good condition, it is to make a parallel connection to the one you have, it is easier and more economically counting talking, but if you want to stop manufacturing if there is the replace There a fuse and a command relay, check these parts before doing anything, wish is not true what they told you and want to deceive you, try to see what happens.
16 years 2 months before #7518 by manual-mecanica
Thanks for your answer, what I forget to say is that when I turn the steering wheel anywhere to Eltope if I whistle but in normal position no
16 years 2 months before #7593 by manual-mecanica
Hello, the most likely to have wear in the rumble.
