intermittent airbag witness
16 years 3 months before #7330 by manual-mecanica
Intermittent Witness of the Airbag published by Manual-Mecanica
] Hello everyone, and thanks in advance, I would like to know if this is a serious problem ...
I have a Peugeot 206 HDI 2.0 vehicle and from good to first the airbag witness began to flash and I don't know what the reason is. I checked its fuse (in the manual is the number 1 of the fuse picture, put shunt, and in the fuse only 32V, but not the amperage, and according to the manual that fuse is for more things) the case is that the fuse works and the flicker continues. Solve it, if Alguein has, knows or knows this problem, please give me some answer. Thanks [/size]
16 years 3 months before #7338 by manual-mecanica
Manual-Mecanica Response on the Re: Intermittent Witness of the Airbag
Look, it is not very combined to solve these types of problems if you do not possess the knowledge since if the airbag is opened by brother you get more expensive, to be able to saver that happens it is necessary to make a Scaner and that the problem is found through the computer.
16 years 3 months before #7339 by manual-mecanica
It is true of a scam to know the error code and not being guessing and changing things by supocision when the airbag focus is activated means that there is a malfunction of the system and in case of impact the air bag would not be activated for your protection We wait for you to do what is said here.: Woohoo:
16 years 3 months before #7344 by manual-mecanica
Thank you for your answers, in no case was my intention to fix the problem I alone, it was just knowing the problem and knowing more or less what your solution and cost is. I will wait for me to meet in Peugeot and once the diagnostic machine will tell me what the problem is. Thank you.
