Diesel party start problem
16 years 2 months before #7432 by manual-mecanica
Manual-Mecanica Response on the Re: Problem Start Diesel Party
The filter is not a proable one in diesel vehicles, from the point of view that you propose, now in vehicles with electronic injection, either that it is found before the flow and generally it is thus Endia today.
16 years 2 months before #7435 by manual-mecanica
To test the heater disconnects the heaters, connect a driver to the battery positive and one by one try them: if you have current consumption they are good, so that you do not confuse you connect an amperimeter in Seri, to know that they are not short -circuit.
I recommend you: If when you start notes that guide strongly and the spark plugs are good, with sults the problem with your mechanic
13 years 9 months before #26083 by manual-mecanica
Hello, although it has been a long time since the 1st consultation, just saying that the start has improved and for the following:
when the heater light is turned off I wait about 4 seconds to give the march to the march and much improvement is noted in winter.
I hope it helps
greetings
