Problems with 3 cylinders of V6 Toyota
16 years 3 months before #7289 by manual-mecanica
Problems with 3 cylinders of V6 Toyota published by Manual-Mecanica
Hello everyone can help me with this problem at the beginning the engine work the 6 cylinders but after 10 seconds later only the three of the right side of this 3 Vz engine and the 3 on the left side are left without working. I already changed the injectors, calbes, distribution cup, rotor. Well I don't know what is happening. But I hope someone helps me. Thank you
16 years 3 months before - 16 years 3 months before #7309 by manual-mecanica
Manual-Mecanica Answer on the Re: Problems with 3 cylinders of V6 Toyota
Did you change the spark plugs? I suppose you had your car and you appear to ignite the cylinders, before having changed cables and injectors, you would have done a spark spark
Latest edition: 16 years 3 months before by .
16 years 3 months before #7335 by manual-mecanica
Your case seems very strange to me, you are sure that the three do not work? What kind of distribution do you have, that is, with normal coil coil or distributor, give me a little more detail, to be able to help you, I do not know the engine very well but I think it resembles that of the Ford Aerostar, is it strange that they are the three unless they have an electronic command, divided for both sides, like a signal or there, like a sign of the signal, like a sign.
16 years 1 month before #7748 by manual-mecanica
Hello if you have a problem with the 3VZ engine, you have the 22R manual that includes the 3VZ engine, and if the injection in the cylinder is directly related to the flow rate in the manual explains how to control all these ITEN. a hug
