Read codes ABS Cherokee 98
16 years 4 months before #7181 by manual-mecanica
Read codes Failure ABS Cherokee 98 Published by Manual-Mecanica
Hala dear foristas would like to know if any way to read the fault codes of the ABS of a Cherokee 4.0 naphthath of the year 98 without the need for scanner since mine is for injection nothing more in that vehicle
before all thank you very much thank you
Cristian
16 years 3 months before #7191 by manual-mecanica
Manual-Mecanica Answer on the Re: Read Codes Failure ABS Cherokee 98
It may be that you achieve it with the blink code but you need the list of them which is the defect that makes you, review and clean all the wheel sensors and the physical wheels of each one .-
