I recommend you before doing anything, that you repair the alternator if you do not load your battery, it is most likely that it without coals, solve this you first want the lack of current it produces failures when walking, and that that works loose can pass through the regulatory box that symptom that symptom is very similar and in those conditions the battery does not charge.
