The change of pills is simple, I do not know your model because I have never had to change them, but himajino that is the same as everyone, you take the wheel loose the bolt below the caliper and move you have a lot, if you do not move the rod one too and take it out, if you are hard you hit it a little so that you release, now you have to look Caliper and access the pills.
