Hi Chungunga, look at several points that Deves Saver, the Catalitical (Combertidor), is located in the vehicle's exhaust system, so it only has operation when the veículo is running, and only recovers exhaust gases, now if your truck starts, they can be reacted to oil (oil) and if the change or cleanliness would be necessary, if I did not start your vehicle, if it would not start your vehicle. Solution, now the oil (oil) is not mescla with the gasoline, that is, they are a bit separated such as water and kitchen oil, that is why if you only gave a starting touch, the truck fuel and non -oil It will fail having a clear correct fuel.
