Hot starting problems
16 years 8 months before #4896 by manual-mecanica
Hot starting problems posted by manual-mecanica
Hello, the game costs a lot after the engine has a time arrested and I want to start it again, it only occurs when it is hot or normal operating temperature for a while, in cold part of wonder.
16 years 8 months before #4897 by manual-mecanica
Manual-Mecanica response on the Re: hot starting problems
I mean a Mercedes Benz 300 and year 1987,
thanks
16 years 8 months before #4901 by manual-mecanica
Hello, if it is the body (124) you carry ke-jetronic injection, you have to check the gasoline pressure (5.3 to 5.5) bar. And the temperature sensor (325 ohm at 80 cº). If everything is correct the failure is in the injection body.
PS: In these models they usually spoil a lot.
16 years 8 months before #4902 by manual-mecanica
Thank you very much, I think the issue goes for the information of the Tº since it only happens after getting to normal, you will see it as the first point.
