Hello good, I have a Husqvarna te 125 4t of 2012, and I have 2 problems that I do not know if they are alien to each other or have something to do, to see if you can help me.
The first problem is that the motorcycle gets heated, but the weirdest thing is that as colder it is more heated, I mean that the days that is very hot, and now that it is summer, also in the peak hours, nothing gets hot, and it is when it goes better. The cooling circuit has pressure, bone that is fine.
As for the other problem, today I open the water pump box (I think it is called that, I'm not sure) to check that it was fine, and if I was, the only thing that was found oil inside, very little, but there it was. And looked at the cooling deposit and no oil, I was clean, I mean that these are my two problems, I need help. thank you so much!
