GA15 engine
6 years 3 weeks before #53785 by manual-mecanica
GA15 engine posted by Manual-Mecanica
Hello, does anyone have or know where I can find the Nissan Vanette workshop manual, carburacion with G-A15 motor?
I need to know the ignition degrees to adjust the one of the platinums since I have the ignition very delayed (petardeba when leaving accelerator) I have solved it by advancing the ignition but I want to adjust it as much as possible to its state of factory.
I also need the electrical diagram, since I skip the motor fuse (the second fuse) without any apparent reason, the van works perfectly despite the molten fuse, I wanted to know where the failure can be with the electrical diagram.
All the best
