Rear brake noise from Focus C max
16 years 9 months before #4574 by manual-mecanica
Rear brake noise from Focus C Max published by Manual-Mecanica
Hello, I have a CMAX and from time to time it makes noise on the rear wheels, noise similar to the bearing, but when stepping on the brake it is removed, also when braking squeak the pills too much (the pills were put 200km ago), the pills are nect.
16 years 9 months before #4581 by manual-mecanica
Manual-Mecanica Answer on the Re: Rear brake noise of Focus C max
Do you have electric hand brake? If so, you have to make learning the position of the pistons.
The chillido noise that brakes make is very difficult to remove, when not impossible. The cause is the material with which the lining of the pills is manufactured. This is no longer done with asbestos, it is prohibited in the EU because it produces cancer and pulmonary emphysema if it is breathed. The material used now hardens faster and that's why it makes more noise.
16 years 8 months before #4628 by manual-mecanica
Did you rectified the album or did you change the pills nothing more? If you did not rectified them, it will take time until the pills take the form of the album.
16 years 8 months before #4633 by manual-mecanica
Check the clamp if you put it well there can be some rubbing my advice disassembles and observes if something is seen, some friction of the pill or clamp or support.
