Hello, Hyundai Verna (Accent) 2004, a tree cams, 12 valves, when the engine is heated, it begins to sound a lot, as hydraulic divers, but it has power, it is economical, it works very well, but it makes a lot of noise, it is added additive remurs and new oil, asks all these models sound? Is any factory defect? Any partner already found the fault? Share, thanks
Hello. Regarding the engine noise, I tell you that the same thing happened to me with a Samurai Suzuki. The problem was the camshaft, it had a wear that when the engine started it had a normal sound but when the engine was heated, a noise appeared like valve pounding. The solution was to rectify the camshaft.
