Hi, I'm new here, I'm a mechanic, I have problems detecting the fault.
The car is a Ford Focus 2008, Zetec Rocam 1.6 engine, the fault makes it in fourth when you stretch it a lot, but more in fifth when you reach 110km. What the scanner throws is P300 and P304. I changed coils, spark plug wires, gasoline pump, replacement fuel, I made cylinder and rings cover due to low compression doubts. The escape also probes it. That waiting for your answers, thank you very much, a month ago that I rename with the car, even consult with mechanics in the area and nothing ...
