Apparently the focus is from 2000, I have disassembled the radiocaset and there are 2 loose connectors, each with 3 cables, and each cable is bicolor, I have placed the resistance between 2 cables that were brown and green with other colors since the others had none of these 2 colors. The problem is that the failure does not always manifest, sometimes it goes out when starting, sometimes when you are walking a while and identically it can go. Of course, the same is always repeated, needles down suddenly and lowering, lighting motor and digital display does not mark.
Hopefully the reistence is well placed and solved like this.
Thank you so much
