Melstes with a multimeter in which voltage is the TPS must be at 0.5V 500mv. I recommend that the IAC valve in 900 or 1000 rpm when you do that disconnect the pacha and look how pump pressure evolves 36 or 38 Lbras looks at the residual pressure that does not get off 10 psi after which you turn it off
