Hello, I would like to exchange information about the ignition of a 2014 Nissan Navara, it is changed torokes, it is armed according to catalog and does not start, I made the review again of the assembly, the synchronization of the two chains is correct, but I have a doubt, the right camshaft is the one that carries the signal of the signal in the tail, where the signal Cams axis, it is in the draft groove, but does not act with the sensor, I think it is missed its position, in what I could inform myself, the APA axis sensor works together with the position of the crankshaft.
I did the sensor operating manual test while we should start and accuse several attempts to start, of course generating the pulsation bringing a workshop key, with that discarding that the sensor was bad, but still does not start.
