Hello, I am new in the forum, I have a Hilux 2.5 TD mod. 2006 since I bought it that I have problems with the injection check, the witness of the board is turned on and the engine loses strength, I turn off the engine I turn on again and it is working normally until at any time the witness of the injection check is turned on again.
When they scanned it the first time, it accused exesive fuel leakage, they cleaned the pump and changed the flow regulatory valve, cleaned the injectors and the ramp and changed the Oil gas filter. Anduo almost a month until the same problem returned.
They returned to Scaar gave the same fault, calibrated the 4 injectors, repaired them and changed 2 platelets of them, Andubo 15 days, now it makes the same fault they tell me to try to change the filter, which must have some garbage spinning, the Scaner pulls Stanqueity failure in the fuel system or something that is no longer what you do.
If someone can advise me about it, I'm going to burns it.
